I'm implementing a datalist action plugin. I can compile the plugin and correctly load it using the plugin manager. However when I add it to a datalist and press the associated link the executeAction() function is executed twice. Why is it happening? Am I doing something wrong?
This is a link to the test application
This is a link to the  jar of the plugin.
This is the code of the plugin (I kept it the more minimal as possible for the sake of clarity):
package org.joget.tutorial;
import java.io.File;
import java.io.FileInputStream;
import java.io.FileNotFoundException;
import java.io.FileOutputStream;
import java.io.IOException;
import java.net.URL;
import org.joget.apps.app.service.AppPluginUtil;
import org.joget.apps.datalist.model.DataList;
import org.joget.apps.datalist.model.DataListActionDefault;
import org.joget.apps.datalist.model.DataListActionResult;
import org.joget.apps.form.service.FileUtil;
public class GenerateNewDocumentVersionDatalistAction extends DataListActionDefault {
    private final static String MESSAGE_PATH = "messages/GenerateNewDocumentVersionDatalistAction";
    private static int execution = 0;
    public DataListActionResult executeAction(DataList arg0, String[] arg1) {
            LogUtil.info("CollboartiveEditing - Plugin creating new document version", "Generating test document: run " + execution);
            execution++;
        return null;
    public String getConfirmation() {
        //LogUtil.info("Collaborative Editing - Generate new document version plugin", "getConfimation: " + getPropertyString("confirmation"));
        //return getPropertyString("confirmation"); //get confirmation from configured properties options
        return null;
    public String getHref() {
        //LogUtil.info("Collaborative Editing - Generate new document version plugin", "getHref: " + getPropertyString("href"));
        return getPropertyString("href"); //Let system to handle to post to the same page
        //return null;
    public String getHrefColumn() {
        //LogUtil.info("Collaborative Editing - Generate new document version plugin", "getHrefColumn: " + getPropertyString("recordIdColumn"));
        //return getPropertyString("hrefColumn"); //Let system to set the primary key column of the binder
        return null;
    public String getHrefParam() {
        //LogUtil.info("Collaborative Editing - Generate new document version plugin", "getHrefParam: " + getPropertyString("hrefParam"));
        //return getPropertyString("hrefParam");  //Let system to set the parameter to the checkbox name
        return null;
    public String getLinkLabel() {
        //LogUtil.info("Collaborative Editing - Generate new document version plugin", "getLinkLabel: " + getPropertyString("label"));
        return getPropertyString("label"); //get label from configured properties options
        //return null;
    public String getTarget() {
        ////return "post";
        //LogUtil.info("Collaborative Editing - Generate new document version plugin", "getTarget: " + getPropertyString("target"));
        //return getPropertyString("target");
        return null;
    public String getClassName() {
        return getClass().getName();
    public String getLabel() {
        return AppPluginUtil.getMessage("org.joget.tutorial.GenerateNewDocumentVersionDatalistAction.pluginLabel", getClassName(), MESSAGE_PATH);
    public String getPropertyOptions() {
        return AppUtil.readPluginResource(getClassName(), "/properties/generateNewDocumentVersionDatalisAction.json", null, true, MESSAGE_PATH);
    public String getDescription() {
        return AppPluginUtil.getMessage("org.joget.tutorial.GenerateNewDocumentVersionDatalistAction.pluginDesc", getClassName(), MESSAGE_PATH);
    public String getName() {
        return "New Document Generator Datalist Action";
    public String getVersion() {
        return "5.0.0";
When I click on the action link in the datalist in the log file I get the following output:
INFO  20 Nov 2017 14:55:01 CollboartiveEditing - Plugin creating new document version  - Generating test document: run 0
INFO  20 Nov 2017 14:55:01 CollboartiveEditing - Plugin creating new document version  - Generating test document: run 1
      Hi, I believe you need to return a DataListActionResult object in your executeAction instead of null. You can try referring to some of the existing action classes in https://github.com/jogetworkflow/jw-community/tree/5d71cfabb90767e9ee9db461a80bb221859d2fea/wflow-core/src/main/java/org/joget/apps/datalist/lib
      1. Roberto Larcher
        It works, thanks. Taking inspiration from the FormRowDeleteDataListAction.java class I removed the return null row and added the following lines: DataListActionResult result = new DataListActionResult(); result.setType(DataListActionResult.TYPE_REDIRECT); result.setUrl("REFERER"); return result; I didn't really understood what I'm doing with result.setUrl("REFERER"); but it works
