Cannot upload file
I need user to upload 4 files. But it takes a few time until it successfully submitted. After it was submitted, I checked the details and not all files are uploaded. I've been trying to change the form few times and the same thing still happen. Do anyone knows why this is happening?
      Hi guys, I have recently experienced the same with the latest version of Joget 6. The file upload only works occasionally but the log doesn’t give me an error until I try to retrieve the file (i.e. file not found). Owen Ong, any ideas? Cheers
        Is there any error in log file?
        1. Nurul Akhmar
          Hello KL Lee. Is this the kind of error that you meant? If so, what should I do? ERROR 01 Mar 2018 17:31:27 org.joget.plugin.enterprise.SqlChartMenu - Not able to retrieve data from binder
        2. Nurul Akhmar
          Hello again. So I changed my file upload into image upload and make all four of them mandatory but the problem still persists. I have to submit at least 5 times before it can be submitted. Which log should I look for the error?
        3. KL Lee
          maybe u should try to upload the file directly from Joget server itself. If able to do so, then might be network issue between the computer and server.
