I have setup a dev and prod environment, how do I transfer my forms, processes and data from dev to prod?
      Hi, you can export your app from dev and then import it into prod following Import and Export Apps. Alternatively you could backup and restore the entire installation following Deployment Best Practices#BackupandRestore
      1. Camilo A. García
        This method also works to migrate from version 5 to 6? That is, if I do a clean installation in version 6, on the basis of data that version 5 was using, it degrades some function?
      2. Voon Lok
        Thanks Anders :)
      3. panda
        for v5 to v6, there is an Upgrade Guide at https://dev.joget.org/community/display/KBv6/Upgrade+Guide. But i see the method will work too.
      4. Voon Lok
        Hi, would the export/import app be suitable to push in incremental changes like adding new fields and forms? Or should I manually create them in the production environment
