The error specifically indicates that undefined variable or class name: workflowAssignment This could mean it wasn't initialized properly. Try the below code to verify the same.
if (workflowAssignment != null) { LogUtil.info("Value of workflowAssignment : ", workflowAssignment.toString()); } else { LogUtil.info("workflowAssignment is null",""); }
Additionally check if you have imported the necessary package
import org.joget.workflow.model.WorkflowAssignment;
Let us know if this works. Please share your full beanshell script if possible for further debugging.
and here now the two scripts:
This is working:
Route A has a transition to Tool B.
Bean in Route A
import org.joget.workflow.model.DecisionResult;
String groupsRequested = "#form.account_signup.groupsRequested#";
int groupsRequestedArraySize;
String[] groupsRequestedArray = groupsRequested.split(";");
if (groupsRequested != "") {
groupsRequestedArraySize = groupsRequestedArray.length;
} else {
groupsRequestedArraySize = 0;
int groupCounter = Integer.valueOf("#variable.groupCounter#");
//LogUtil.info("Value of groupCounter : ", "" + groupCounter);
//LogUtil.info("Value of groupsRequested : ", groupsRequested);
//LogUtil.info("Value of groupsRequestedArray : ", Arrays.toString(groupsRequestedArray));
//LogUtil.info("Value of groupsRequestedArraySize : ", "" + groupsRequestedArraySize);
DecisionResult result = new DecisionResult();
if (groupCounter >= groupsRequestedArraySize ) {
result.addTransition("noGroupUpdate");
// LogUtil.info("Value of Transition : ", "noGroupUpdate");
} else {
result.addTransition("groupUpdate");
// LogUtil.info("Value of Transition : ", "groupUpdate");
result.setIsAndSplit(true);
return result;Bean in Tool B
//LogUtil.info("Value of workflowAssignment : ", workflowAssignment.toString());
String group = groupsRequestedArray[groupCounter++];
wm.activityVariable(workflowAssignment.getActivityId(),"group", group);
wm.activityVariable(workflowAssignment.getActivityId(),"groupCounter", String.valueOf(groupCounter));
//LogUtil.info("Value of group : ", "" + group);This is not working:
All code is in the Bean for Route A, not Tool B.
int groupsRequestedArraySize;int groupCounter = Integer.valueOf("#variable.groupCounter#");
wm.activityVariable(workflowAssignment.getActivityId(),"group", group);// This line above throws already error since workflowAssignment is null
wm.activityVariable(workflowAssignment.getActivityId(),"groupCounter", String.valueOf(groupCounter));if (groupsRequested != "") {
} else {
}int groupCounter = Integer.valueOf("#variable.groupCounter#");
} else {
return result;Add your comment... - 10-1
I checked the same code in a tool and not inside a route bean. It works there. So it seems, that workflowassignment is not propagated to the route bean but only to a tool bean.
I cannot think of any reason why this should be a feature and not a bug.
Anyway by splitting the code into a tool and a route it is possible to work around it.
Using version 8.1.6 community. Implemented a bean for a route. The following two lines of code:
LogUtil.info("Value of activityId : ", "#assignment.activityId#");
give the following result, which is unexpected:
INFO 28 Oct 2024 12:25:59 Value of activityId : - #assignment.activityId#
2193
ERROR 28 Oct 2024 12:25:59 org.joget.apps.app.service.AppPluginUtil - Error executing script, line number: 34
2194
bsh.EvalError: Sourced file: inline evaluation of: ``import org.joget.workflow.model.DecisionResult; import org.joget.commons.util.Lo . . . '' : Attempt to resolve method: toString() on undefined variable or class name: workflowAssignment
