- 321Hi If you link the first form in your process to "Run Process" map, there will not be any 'save as draft' button as the record and process has not been created yet. To see the 'save as draft' button, map your first form to an activity after the start process or after the green circle icon in design process. In addition, do not click the checkbox "Remove Save as Draft Button" in Map Activities To Form. Thank you. Add your comment...
- 10-1Thanks Add your comment...
I need to show save as draft in the run process but it us showing only submit button.
Please help
