Hey there,
I'm unsure of the objective of using REST API to delete external datasources.
However, if you require a Delete datalist action for your datalist, you can use JDBC Datalist Action and write your custom SQL statement here to delete external datasource records.
Hope this helps.
- NFMJ
Just want to know if you ever try using rest API in bean shell scripting?
HI,
How can I use rest API to delete the external source from joget apps. Since for what I have known, joget already provide delete function /button in each datalists. But what I need, when I click the delete button, data from the external source with same id also deleted. Please help me.
