Surveys with Joget
Can we make surveys with Joget? If yes can the survey be not monolithic? I mean not with only one direction but with choice-based branching.
      Hi, yes I don't see a reason why not. For choice-based branching, you can use Show and Hide Form Sections (Section Visibility).
      1. Nik
        Yes I agree. It is the only feature you can use for surveys. But I don't like that visibility is determined by the target section and not the trigger section.
