Would like to check how to change the App Center back to default UI after publishing some customize UI.
Not able to find the default UI from the setting list.
      Hi Christopher, The App Center itself is a Joget application, just like any other app you build within the platform. Unless you created a new version before modifying the default App Center, you cannot easily restore it to its previous version.
      If you did create a new version before making your changes, you can simply delete that version and your App Center will revert to its previous state. Note that all your modifications will be permanently lost.
      If you didn't create a version beforehand, here are three solutions to restore your App Center:
      1. Import from another environment: Export the App Center app from your development or UAT environment, then import it to your current setup.
      2. Use a fresh installation: Perform a new Joget installation, export its default App Center, and import it to your environment.
      3.  Import the attached App Center package to immediately restore the default UI.
       Hope this helps.
