how to calculate date difference?
dear experts,
I have 2 form, A and B.
Form B contain the list of dates (7 dates) and the calculation executed here
Form B also act as subform in form A
below is the codes to calculate the difference between dates,
It works perfectly when in preview mode. but the scipt would not work when i place form B as subform
$(function(){
$('input[name="dateStart"], input[name="dateEnd"]').change( function(){
      d1 = $('input[name="dateStart"]').datepicker('getDate');
      d2 = $('input[name="dateEnd"]').datepicker('getDate');
      diff = 0;
      diff = Math.floor((d2.getTime() - d1.getTime()) / 86400000); // ms per day
      diffy = Math.floor((d2.getTime() - d1.getTime()) / 86400000); // ms per day
      $('input[name=days1]').val(diff);
      $('input[name=datediff1]').val(diffy);
      i used this codes
      var fieldD1 = FormUtil.getField("dateStart");
      var fieldD2 = FormUtil.getField("dateEnd");
      var fieldD3 = FormUtil.getField("test");
      $(fieldD3).val(fieldD1);
      The results = Object object
      How to solve ya??? thanksss
      1. Anders
        Instead of using fieldD1 which is the actual field, you can try using fieldD1.val() to obtain the value.
      Hi, instead of using input[name=field] perhaps you can try using the Javascript API#getField(fieldId)
