How I customize the confirmation screen ?
I need to customize the screen displayed when "Run process without confirmation screen?" is not checked in the section "Edit Run Process > Redirection > Advanced > Performance" (USERVIEW BUILDER).
For the moment I have the name of my application twice and a "run process" button.
Thanks in advance,
Matthieu.
      Hi, I believe you can use CSS and JavaScript to customize that screen. Use your browser developer tools to inspect the elements that need to be changed, and in your Userview Theme settings you can place your Custom CSS and Custom JavaScript as required.
