How I get current form data in a plugin used as Post Processing Tool of this form ?
I saw that it is possible to connect a plugin to a form as Post Processing Tool but I can't find how to get data from this form. With the form path it's OK as well. I just want to know which form did the last action (create,update, delete) to update other tables in database.
Thanks,
Matthieu.
      It was a plugin of mine. Finnaly I managed it doing something like this :
      // Form declarations
      String myElementId = "ident";
       Form form = FormUtil.findRootForm(element);
      Element myElement = FormUtil.findElement(myElementId, form, formData);
       String[] values = FormUtil.getElementPropertyValues(runway, formData);
      // Plugin declarations
      PluginManager pluginManager = (PluginManager) AppUtil.getApplicationContext().getBean("pluginManager");
      Plugin plugin = pluginManager.getPlugin("com.my.package.MyPlugin");
      Map propertiesMap = new HashMap();
      propertiesMap.put("myElementId", values[0]);
      ApplicationPlugin pluginMng = (ApplicationPlugin) plugin;
      ((PropertyEditable)pluginMng).setProperties(propertiesMap);
      pluginMng.execute(propertiesMap);
      I do it in the store binder of my form.
      Cheers,
      Matthieu.
      1. Anders
        That's great, thanks for sharing your solution!
      2. putri
        what is runway variable here means?
      Hi, what plugin are you using as the Post Processing Tool? To access form data you could try to use the Hash Variable#FormDataHashVariable
