how i can create data binder (directory form binder) plugin
i want to custom dir_user table, and i found little joget app sample for manage user, by default in this sample use directory form binder for load and store data, but i want to more for load and store any field, i try to create plugin it extend to "formBinder" and implement to formLoadBinder,formStoreBinder. but after install this plugin i don't see my plugin in load or store binder(Form Builder properties)
any one to help me.
Thanks in advance.
      1. Chris Angel
        Try check if there is a conflict with the name "DirectoryUserManager" with other plugin. Do not use the same name as another plugin.
      2. Muhammad Khafidz
        thank you Chris Angel
      In the server log, did you check that the plugin has successfully loaded?
