404 error when add row form grid
Hello, everyone.
When I want to add row in form grid, error 404 will appear for few seconds before my form appears. How to fix this?
This is the joget log:
ERROR 25 Feb 2019 16:16:11 Shark - SharkConnectionImpl -> Unexpected error while user roleAnonymous loggs on
bitronix.tm.internal.BitronixRollbackException: transaction has been marked as rollback only
at bitronix.tm.BitronixTransaction.registerSynchronization(BitronixTransaction.java:212)
at org.enhydra.shark.SharkTxSynchronization.<init>(SharkTxSynchronization.java:34)
at org.enhydra.shark.SharkTxSynchronizationFactory.createTxSynchronization(SharkTxSynchronizationFactory.java:93)
at org.enhydra.shark.SharkUtilities.getTxSynchronization(SharkUtilities.java:469)
at org.enhydra.shark.SharkUtilities.getResourceFromCache(SharkUtilities.java:492)
at org.enhydra.shark.SharkUtilities.getResource(SharkUtilities.java:515)
at org.enhydra.shark.SharkConnectionImpl.connect(SharkConnectionImpl.java:73)
at org.joget.workflow.model.service.WorkflowManagerImpl.connect(WorkflowManagerImpl.java:4763)
at org.joget.workflow.model.service.WorkflowManagerImpl.connect(WorkflowManagerImpl.java:4748)
at org.joget.workflow.model.service.WorkflowManagerImpl.getRunningProcessIds(WorkflowManagerImpl.java:4999)
at sun.reflect.GeneratedMethodAccessor393.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.springframework.transaction.interceptor.TransactionAspectSupport.invokeWithinTransaction(TransactionAspectSupport.java:281)
at org.joget.apps.app.service.SqlFilterAspect.invoke(SqlFilterAspect.java:36)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:213)
at com.sun.proxy.$Proxy80.getRunningProcessIds(Unknown Source)
at org.joget.workflow.shark.DeadlineChecker.runMe(DeadlineChecker.java:155)
at org.joget.workflow.shark.DeadlineChecker.run(DeadlineChecker.java:131)
ERROR 25 Feb 2019 16:16:11 org.joget.workflow.model.service.WorkflowManagerImpl - bitronix.tm.internal.BitronixRollbackException: transaction has been marked as rollback only
      This problem is solved already. It's because of the context path I set.
        Hi, the error message mentions deadline checker so it should be unrelated. What version of Joget are you using?
        1. Nurul Akhmar
          Hi Anders, I'm using V6
