plugin FormLoadMultiRowElementBinder doesn't work
I am trying to implement a multirow form load binder to have custom rows but it doesnt work. The form grid doesnt display my rows.
Is someone already used successfully a multirow form load binder plugin and could explain me how it works?
Please don't answer me with a link to the documentation, it's rather useless...
Thanks,
Olivier
public class MyMultiRowLoadBinder extends FormBinder implements FormLoadBinder, FormLoadElementBinder, FormLoadMultiRowElementBinder {
    public FormRowSet load(Element element, String key, FormData formData) {
		String formId = element.getPropertyString("formDefId");
        setProperty("formDefId", formId);
        setProperty("foreignKey", key);
        FormRowSet displayedRows;
		displayedRows = ... some computation (I set foreignKey in rows)
        return displayedRows;
      I do not understand your question. I tried a simple code like below for a form grid:
      import org.joget.apps.form.model.FormLoadBinder;
      public FormRowSet load(Element element, String primaryKey, FormData formData) {
          FormRowSet rows = new FormRowSet();
          rows.setMultiRow(true);
          FormRow row = new FormRow();
          row.setProperty("value", "55555");
          row.setProperty("text", "Laugh");
          rows.add(row);
          return rows;
      //call load method with injected variable
      return load(element, primaryKey, formData);
      The code above works so this is not a Joget problem. I need more information regarding your plugin.
        Thanks a lot!
        It was just missing the following line
