Anders Requesting in case you know the answer for this
- Vincent
Hi Chris, thank you for tagging, please help need advice how to do this if it needs to change Sync LDAP code to handle this or is there another way to do it in a minimal code. Thank you :)
- Anders
I am not sure but I believe you would need some custom code to sync additional information. If you have an enterprise support account you could try to make a request there.
- Vincent
Custom code to sync additional information means using a Bean Shell to achieve it?
- Justin
More likely have to create custom directory manager plugin.
Hi, I would like to know if what would be the best way to get Department and Company inside Sync LDAP plugin, seems that only basic information is in there.
