Hi, I need a server-side action because I need to call an existing plugin without exiting the form
- Anders
If you need some server-side action without submitting the form, then you would need to use something like an AJAX call using client-side JavaScript to a server-side API. For the server-side you could have own your custom web service or build a https://dev.joget.org/community/display/KBv6/Web+Service+Plugin
Hi, if you do not need a button to perform any submission or server-side action then it would be easier to just add a button with an onclick event in a Custom HTML element, instead of creating a custom plugin.
I'm trying to use FormBuilderPaletteElement interface to create a button able to launch a plugin.
I don't need a submit button. I need to stay on the form.
Could someone give me an example? There is no documentation for that..
In particular:
Where to put the code to execute on button click?
How to change the label button?
Thanks,
Olivier
