Hi, yes definitely possible. Found a previous question How can one automatically run an activity on new item from a datalist? and also example at Start a Process from External Page. Or you can also use a scheduler to periodically check and run processes How do I create a scheduled task to process all records, E.g. Add late payment records on a monthly basis?
- abdul Fattah
okay i already get the plugin. But based on my trying of that plugin, i can see i need another plugin to make it work. it is true?
- abdul Fattah
can help?
- Ian
I'm assuming you're talking about the scheduler plugin in the Joget Marketplace? if you look in the notes section it mentions it needs JSON POST API plugin. Hope this helps.
- abdul Fattah
okay tq for that IAN. But it is have another method to solve it for this question besides use the scheduler plugin?
Currently i have one project that need a process can be running without click submit button or etc, it is possible? Means automatically run process once we update the data directly in database. So, after that, process will be run to tool. it is possible?
