pass field containing url to html
Greetings - I saw a few people asked this previously:
I have a field (urlstring) that stores a web url (www.google.com) . table name is mylinks and the form name is Links for example...
I tried to setup a custom HTML to allow a clickable experience but its now working ...
<a href="#form.mylinks.urlstring#" target=_blank>test2</a>
is this the right approach to creating a link that a user can click to get to www.google.com?
thanks
tony
      So it works if I save the record and I go back since it can read the table ( since it's stored). Is there a way to read the value in the URL text field and pass it to a variable in the custom html?
      This value is also passed as a parameter... Is there a way to read this parameter and store it as a variable with a script?
      Cheers - Tony
        I think the issues is that I am passing the values from a JDBC list, so there wouldn't be any record in the table unit I save/ trigger process... might have to find another way to populate the HTML from the list....
          Thanks Ian - I am getting the following:
          http://#form.mylinks.urlstringl# for some reason it is not passing the value of the hash variable...
          1. Anders
            Hi, if your form does not have a implicit record ID to be able to retrieve the appropriate row, you could try providing the correct record ID e.g. #form.tableName.fieldId[recordId]# as mentioned in Hash Variable#FormDataHashVariable.
          It has to be an absolute URL.
          from your example, you can either :
           <a href="http://#form.mylinks.urlstring#" target=_blank>test2</a>
          or ensuring when u store a web url, you store it as an absolute URL.
          urlstring = http://www.google.com
          hope this helps
