Look good when preview as below:
But when click new as below:
How can i remove the extra column ???
Thank you
      Matthew King, thank you for you info. however, i using cloud version. any solution for it ???
      1. Matthew King
        The Joget Cloud is running the latest version. Could you attach your app for the community to check? Also kindly indicate which browser are you using to access Joget.
      I think this issue has been fixed in the latest Joget Professional/Enterprise v6.0.20 version (download from https://www.joget.org/download/).
      I don't see any extra column in my advance grid on v6.0.20.
      1. ackainu
        try to download the newest joget version and you will see it again
      2. Haider Ali
        @Mattew King I am currently evaluating latest version of Joget Pro  version and this issue is still exists , i am current using 10 columns in grid.
      3. Haider Ali
        if I inspect these extra column they have visibility hidden but still showing
