Hi, I am assuming you mean JavaScript sessionStorage? In this case that is stored at the client browser. You could try passing it to the URL eg https://stackoverflow.com/questions/5999118/how-can-i-add-or-update-a-query-string-parameter, then use a Hash Variable#RequestParameterHashVariable
- Aorka
I'm follow by example and It is working.
Thank you for your support.
Aorka.
How can i pass sessionStorage values to extra filter condition in the Datalist Builder?
*** URL Request Parameters for Datalist it appears in element "popup select box"
Thank you.
Aorka.
