Javascript question - custom HTML
Greetings - I have javascript question, so excuse the lack of programming language.
I am monitoring for text field changes and it works fine with the following snippet line:
$('input[name="status_current"], input[name="status_new"]').change( function(){
The "input" above doesnt work with select box where you change the value based on the dropdown value.
is there a different method I can use?
thanks
Tony
      Hi, instead of $('input') you should try to use Javascript API#getField(fieldId).
        try to use below to get the value of the option selected
        $('select').on('change', function() {
        alert( this.value );
        1. Anthony Sica
          Hi - thank you for your input. I tried both methods, but it wont fire... I would like to fire when the select box called "PONumber" changes value. in this example, I simply read the value of the iAmount and update "POImpact" accordingly.
          <script>
          $(getField("PONumber")).change( function(){
                var iAmount = Number.parseFloat(FormUtil.getValue("Invoice_Amount").replace(/[^0-9\.-]+/g,""));
                $('input[name="POImpact"]').val(iAmount);
          $("PONumber").on('change', function() {
          </script>
        2. Anders
          It should be FormUtil.getField("PONumber") instead of just getField("PONumber")
