Hi, I have been able to run Enterprise Edition on Weblogic 12c successfully. What edition are you using?
The error message does indicate that you are facing a database connection problem rather than a weblogic one, most like a JDBC driver problem like in https://stackoverflow.com/questions/46131295/classcastexception-java-math-biginteger-cannot-be-cast-to-java-lang-long-on-con
- Chandrasekaran
Hi Anders,
we are trying that in Free Community edition, Any hints or pointers that community edition is compatible with Weblogic12c.
Rgds
Chandy
- Chandrasekaran
Hi anders,
On the same line,trying to connect oracle db instead of Mysql.
Got this error while deploying
Caused by: java.lang.NoSuchMethodError: org.mozilla.javascript.tools.shell.Global: method <init>()V not found
On acccessing the jw.
Caused by: org.hibernate.HibernateException: Connection cannot be null when 'hibernate.dialect' not set
Rgds
Chandy
Trying to deploy joget workflow(jw.war, jwdesigner.war) in jdk1.8 weblogic12C,backend is configurable(mySQL or ORACLE) facing too many issues
faced
Nov 13, 2019 12:54:18 PM org.apache.tomcat.jdbc.pool.ConnectionPool init
SEVERE: Unable to create initial connections of pool.
java.sql.SQLException: java.lang.ClassCastException: java.math.BigInteger cannot be cast to java.lang.Long
Rgds
Chandy
