Hi - I think the issue is with how I reference the field value in the where clause... I tried the query works when I have a value (WHERE c_VariantSku = '100102956') ....
#binder.product.Sku# is proper parameter to reference a value in the sku field of the form. keep in mind the data has not been saved to the database, so we can reference it by id....thanks all
Tony
- Anders
Hi, perhaps you are missing single quotes around the hash variable, e.g. WHERE c_VariantSku = '#binder.product.Sku#'
- Anthony Sica
Hi - Alas, I tried with and without the single quotes with no luck....
- Anders
What exceptions do you get in the logs or console? Error messages should indicate what the actual problems are.
Please Try to change column name without Prefix "c_" like this.
SELECT c_VariantPrice as VariantPrice , c_VariantPrice as VariantPrice
FROM aimsware.app_fd_products
WHERE c_VariantSku = #binder.product.Sku#Hope this help.
Hi - I am trying bind a select box with a jdbc query that references a drop down value on the same form:
drop down name: sku
form : lookupproduct
form: product
I tried the following:
SELECT c_VariantPrice, c_VariantPrice
but It doesnt populate....
any hints on how to reference the value from the Sku dropdown in the query?
