Found the issue. It turned out to be "id missing value" on the test_program table when inserting new data.
tried all different ways, still not working...each time I run the "update" process, only a "197_test_gateway_process5" shows up in the ID of the test_program list.
Hi BG, do you fullfill the requirement below?
- INSERT INTO SELECT requires that data types in source and target tables match
- BG
Hi, thank you; but the data types are identical, all text.
Hi, I read over the forum and tried different things it still did not work for me. Trying to put all data from table test_list to test_program. The two tables have almost identical structure.
INSERT INTO app_fd_test_program (c_program_name, c_customerName, c_field7_test_id)
SELECT c_program_name, c_customerName, c_field7_test_id
FROM app_fd_test_listÂ
WHERE (app_fd_test_list.c_field7_test_id IS NOT NULL)
However it just does not work. I am using the Joget Docker image v6 enterprise.
Any suggestion is welcome.
