Hi All,
I got the following error message when I try to build the wflow-core project by maven, it seems need an account to access the Joget official maven repository (http://dev.joget.org/archiva/repository/internal/), where and how can I get the account? Many thanks for any information that, thanks again!
mvn install
[INFO] Scanning for projects...
[WARNING]
Profile with id: 'default' has not been activated.
[INFO] ------------------------------------------------------------------------ _[INFO] [resources:resources ]_
[INFO] Building wflow-core
[INFO] task-segment: [install]
[WARNING] Using platform encoding (GBK actually) to copy filtered resources, i.e. build is platform dependent!
[INFO] Copying 112 resources
[INFO] snapshot org.joget:wflow-wfengine:4.0-SNAPSHOT: checking for updates from joget-internal
[WARNING] repository metadata for: 'snapshot org.joget:wflow-wfengine:4.0-SNAPSHOT' could not be retrieved from repository: joget-internal due to an error: Authorization failed: Access denied to: http://dev.joget.org/archiva/repository/internal/org/joget/wflow-wfengine/4.0-SNAPSHOT/maven-metadata.xm
l
[INFO] Repository 'joget-internal' will be blacklisted
_[INFO] Unable to find resource 'org.xhtmlrenderer:core-renderer:jar:R8-final' in repository central (http://repo1.maven.org/maven2)_
[ERROR] BUILD ERROR
11 Comments
Please use the updated github's link in Building from Source. Thanks.
justin jiang
Thanks Hugo, your reply is a great help for me!
Marcin Hewelt
I also have a problem building Joget from sources after I followed the instructions.
Do you have any pointers for me how to get Joget to build?
Best Regards, Marcin
Walter
Which branch are you checking out and how do you build your project? What is your environment setup? Any other error log?
Marcin Hewelt
Hi Walter,
I checked out the master HEAD (c376465) from github, which by the way is the same commit as HEAD of branch 4.0-SNAPSHOTS. I then installed the 3rd party libs from the WEB-INF/lib dir of the non-source Joget installation with the setup-maven.xml ant file. I wanted to use the existing MySQL server that comes with Joget, but kept getting database connection errors when building. Hence, I installed another MySQL server that I start on port 3306. I had to manually create the database 'jwdb'. The database connection is working, because the jwdb database gets filled with data.
I use mvn 2.2.1 and JDK 1.6.0_35 to build. In wflow-app I call 'mvn install'.
The error occurs in module 'wflow-wfengine' during the test of 'org.joget.workflow.model.TestWorkflowManager'. I attached the complete build.log
The first error that I get is:
And the some time later
And then finally come the ApplicationContext and BeanCreation errors
Is the only error here, that the 'shkprocessstates' table is not created during the test and that I must create it manually?
Marcin Hewelt
After I ran the sql script Joget/data/jwdb-empty, which created the shkprocessstates table, wflow-engine compiled!
However, next problem occurs in wflow-core:
I attached the complete log core_error.log
<edit>Running mvn install in wflow-core a second time succeeded, although I did not chang anything!</edit>
This behavior is a little strange to me, but I am happy that the build works.
nour berro
i have this error when im building joget from surse code
ERROR 03 Dec 2014 00:48:46 org.springframework.test.context.TestContextManager - Caught exception while allowing TestExecutionListener [org.springframework.test.context.support.DependencyInjectionTestExecutionListener@327be569] to prepare test instance [org.joget.directory.model.service.TestDirectoryManager@1a3b7d72]
java.lang.IllegalStateException: Failed to load ApplicationContext at org.springframework.test.context.TestContext.getApplicationContext(TestContext.java:201) at org.springframework.test.context.support.DependencyInjectionTestExecutionListener.injectDependencies(DependencyInjectionTestExecutionListener.java:109) at org.springframework.test.context.support.DependencyInjectionTestExecutionListener.prepareTestInstance(DependencyInjectionTestExecutionListener.java:75) at org.springframework.test.context.TestContextManager.prepareTestInstance(TestContextManager.java:255) at org.springframework.test.context.junit4.SpringJUnit4ClassRunner.createTest(SpringJUnit4ClassRunner.java:111) at org.springframework.test.context.junit4.SpringJUnit4ClassRunner.invokeTestMethod(SpringJUnit4ClassRunner.java:148) at org.junit.internal.runners.JUnit4ClassRunner.runMethods(JUnit4ClassRunner.java:51) at org.junit.internal.runners.JUnit4ClassRunner$1.run(JUnit4ClassRunner.java:44) at org.junit.internal.runners.ClassRoadie.runUnprotected(ClassRoadie.java:27) at org.junit.internal.runners.ClassRoadie.runProtected(ClassRoadie.java:37) at org.junit.internal.runners.JUnit4ClassRunner.run(JUnit4ClassRunner.java:42) at org.springframework.test.context.junit4.SpringJUnit4ClassRunner.run(SpringJUnit4ClassRunner.java:97) at org.apache.maven.surefire.junit4.JUnit4TestSet.execute(JUnit4TestSet.java:62) at org.apache.maven.surefire.suite.AbstractDirectoryTestSuite.executeTestSet(AbstractDirectoryTestSuite.java:140) at org.apache.maven.surefire.suite.AbstractDirectoryTestSuite.execute(AbstractDirectoryTestSuite.java:127) at org.apache.maven.surefire.Surefire.run(Surefire.java:177) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345) at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'setupSessionFactory' defined in class path resource [commonsApplicationContext.xml]: Invocation of init method failed; nested exception is org.hibernate.HibernateException: Hibernate Dialect must be explicitly set at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1338) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:473) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409) at java.security.AccessController.doPrivileged(Native Method) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380) at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264) at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:222) at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261) at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185) at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164) at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:423) at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:728) at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:380) at org.springframework.test.context.support.AbstractGenericContextLoader.loadContext(AbstractGenericContextLoader.java:84) at org.springframework.test.context.support.AbstractGenericContextLoader.loadContext(AbstractGenericContextLoader.java:42) at org.springframework.test.context.TestContext.loadApplicationContext(TestContext.java:173) at org.springframework.test.context.TestContext.getApplicationContext(TestContext.java:197) ... 21 more
Caused by: org.hibernate.HibernateException: Hibernate Dialect must be explicitly set at org.hibernate.dialect.DialectFactory.determineDialect(DialectFactory.java:57) at org.hibernate.dialect.DialectFactory.buildDialect(DialectFactory.java:39) at org.hibernate.cfg.SettingsFactory.determineDialect(SettingsFactory.java:426) at org.hibernate.cfg.SettingsFactory.buildSettings(SettingsFactory.java:128) at org.hibernate.cfg.Configuration.buildSettingsInternal(Configuration.java:2090) at org.hibernate.cfg.Configuration.buildSettings(Configuration.java:2086) at org.hibernate.cfg.Configuration.buildSessionFactory(Configuration.java:1311) at org.springframework.orm.hibernate3.LocalSessionFactoryBean.newSessionFactory(LocalSessionFactoryBean.java:814) at org.springframework.orm.hibernate3.LocalSessionFactoryBean.buildSessionFactory(LocalSessionFactoryBean.java:732) at org.springframework.orm.hibernate3.AbstractSessionFactoryBean.afterPropertiesSet(AbstractSessionFactoryBean.java:211) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1369) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1335) ... 37 more
Tests run: 3, Failures: 0, Errors: 3, Skipped: 0, Time elapsed: 9.122 sec <<< FAILURE!
... 21 more
... 37 more
Please check database connectivity for the build to run test cases.
nour berro
where can i check the db connectivity
i had already joget run
NOTICE: when i tried to build joget 3.1 build succeeded but 4.0 gave that error
Walter
Configure Datasource for Test Case
nour berro
i found the solution:
when i got error in downloading ojdbc6 from maven central repository i opened the joget source in eclips using maven import plugin then i modify the
wflow-jdbc\pom.xml by changing the folowing
<dependency>
<groupId>com.oracle</groupId>
<artifactId>ojdbc6</artifactId>
<version>12.1.0.2</version>
<scope>runtime</scope>
</dependency>
with the following
then i tried to install (mvn install) but i got that error Caused by: org.hibernate.HibernateException: Hibernate Dialect must be explicitly set
but when i tried to not open the files in eclips and compile the app (mvn install) every thing went OK
