You can run the database backup, and the backup routine is dependent on the specific DBMS you are using. If you are using the default MySQL, you can use mysqldump.
Besides the database backup, you also need to backup the <joget-installation-dir>/wflow/ directory. That's all :)
There's a discussion in the v2 forums on backing up at http://dev.joget.org/community/display/FORUM/Backup, and it should be similar for v3. The suggested solution was:
