My idea is to use beanshell more robust, with make my own library (jar). I have develop my java and compile to jar, and it's work when i'm importing it in ide like eclipse. But when i copy it to beanshell plugin in depedency, it can't work. But if i copy library like httpClient.jar it work.
My question is, how to build a jar that beanshell plugin can read it. I have error that my class it's not found by beanshell. Could you give me some guide or reference?
------------------- solved -----------------------
I'm just have done solved this problem, i just have copy the jar to web-inf\lib
Thanx
chait
Hi evilkyro1965,
I am trying to do the same thing. Where did you put the jar file i.e. in which directory of webapps?
host-manager? manager? ROOT? wflow-designerweb? or wflow-wfweb?
Did you defined any classpath variable?
Vlad
The corect answer is wflow-wfweb.
In wflow-wfweb\web-inf\lib, there you must put a jar in order for it to be available in the application.
