Dear All,
I get some problems in using plugins :
1. I don't understand how to use Reference ID Plugin. Can you explain it? How to implement it?
2. What's difference between Email Plugin and User Notification Plugin?
Sincerely,
Saleh Ibrahim
Dear All,
Sincerely,
Saleh Ibrahim
7 Comments
Hi Saleh,
Regarding the Email Plugin and User Notification Plugin, there's a [Email Notifications|KB:Email Notifications] page in the KB that describes the difference. Basically, the former is to send specific email at certain points while the latter is a general notification whenever a new task is created.
As for the Reference ID Plugin, it doesn't seem like there's documentation in the community knowledge base yet. Will try to put up a page there when I find some time soon :)
Hi Saleh, the documentation for Reference ID Plugin is created. Hope it helps
Tracy Lee
Hi Tiensoon, I have a question.
In the sample process of Travel Request, the Reference ID is showed in the Read-Only test Field of form"Travel Requisition Form_ver_1". In the form editor, the advanced property of this element just has a name, not any workflow variable is specify here.
In the Process Configuration page, the reference id plugin is also not pointed to any variable.
I want to know is there any other configuration is set, or how does this ID transferred to the read-only filed?
Saleh Ibrahim
@All : Thanks a lot... I can use it :)
Arnoldo Gonzalez
Hi!! Im trying to do the same that the exaple of the travel request and I can't...could you please help me, I created a workflow variable Refname in the Designer, then I go to the form and in the text read only I put the same name and the workflow variable name this... #variable.refname# and I dont have succes showing the ref id. PLease help!
Hi Diana, for your use case, if you are referring to the sample Travel Request in v2, you must follow the following steps:
Without using workflow variable, the reference ID generated by the plugin will appear in the read-only textfield using the method described above. Condition is, if you create activity form using hr_travel as table name, then you must configure the Reference ID Plugin's "Form Data Table" as hr_travel too.
Luis Paulino Molina
Hola!
Despues de realizar lo mencionado por Tiensoon, se debe de tener completa la parte de (participant mapping) ya que en caso contrario no funciona el (reference ID generated), en mi caso utilice (maps to org chat) la opcion (performer) - submit y funciono correctamente.
